Ana içeriğe geç
How to Repair Damaged Door or Window Casing
Neye ihtiyacın var
  1. How to Repair Damaged Door or Window Casing, How to Repair Damaged Door or Window Casing: adım 1, 1 resimden 1.
    • Sand down the damaged area of the trim using the block sanding sponge to make a smooth surface.
  2. How to Repair Damaged Door or Window Casing: adım 2, 1 resimden 1.
    • Wipe off the excess dust from sanding with a wash cloth.
  3. How to Repair Damaged Door or Window Casing: adım 3, 1 resimden 1.
    • Apply Dap drydex spackling to to the damaged area of the trim using a 1" plastic putty knife.
    • Allow the spackling to dry per the directions on the label.
  4. How to Repair Damaged Door or Window Casing: adım 4, 1 resimden 1.
    • Use the block sanding sponge to smooth out the surface of the trim to match the crevices of the trim.
  5. How to Repair Damaged Door or Window Casing: adım 5, 1 resimden 1.
  6. How to Repair Damaged Door or Window Casing: adım 6, 2 resimden 1. How to Repair Damaged Door or Window Casing: adım 6, 2 resimden 2.
    • Tape the edges around the damaged area of the trim with masking tape.
  7. How to Repair Damaged Door or Window Casing: adım 7, 2 resimden 1. How to Repair Damaged Door or Window Casing: adım 7, 2 resimden 2.
    • Paint the trim to match the original color.
    • Allow the paint to dry before removing the tape.
Sonuç
Repairing chipped and/or broken door or window casing in the home as a do-it-yourself project overall saves time and money. There is no hassle of having to take off of work to meet the installers, no outrageous costs for materials and proper equipment, and no stress because this guide has everything necessary to complete the repair. So have fun, good luck, and happy fixing.
Bir başkası bu kılavuzu tamamladı.
Celeste Conroy
128 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S1-G6, Rauch Summer 2017 Texas Tech, Team S1-G6, Rauch Summer 2017 üyesi
TTU-RAUCH-SU17S1G6
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 2,597
