Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the problematic engine gear inside the helicopter frame.
Grab the screwdriver that will fit the screws on your specific model.
Unscrew the decorative/protective shroud blocking your access to the inside of the helicopter.
If it is possible to reset the gear without unscrewing further, attempt to push the gear back up into place on the motor shaft with a screwdriver or your finger.
Unscrew one side of the frame and set it aside, allowing access to the gear.
Place the screwdriver's tip underneath the clear motor gear.
Firmly push the gear back up into place so that it correctly connects with the main rotor gear.
Return all the pieces to their original place inside the frame.
Screw the frame tightly back into place.
Test the helicopter for functionality.
If it works then the helicopter is fixed and you can screw the shroud back into place.
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Amazing! That repair was genuinely simple to follow directions helped me step by step and I fixed my helicopter for my grandson
