Ana içeriğe geç
How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars
Neye ihtiyacın var
  1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars, How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 1, 1 resimden 1.
    • Remove the main J0 head screw in the center of the binoculars, using the driver with the 4 mm bit and J0 attachment.
  2. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 2, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 2, 2 resimden 2.
    • Remove the top piece and the washers held under the middle screw.
  3. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 3, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 3, 2 resimden 2.
    • Pull the eyepieces off the binoculars.
  4. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 4, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 4, 2 resimden 2.
    • Remove the two side J0 head screws.
  5. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 5, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 5, 2 resimden 2.
    • Remove the four J0 head eyepiece screws.
  6. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 6, 1 resimden 1.
    • Remove the two eyepiece plates.
  7. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 7, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 7, 2 resimden 2.
    • Pry apart the rear rubber covering on each side to expose the two back prism adjustment screws.
  8. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 8, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 8, 2 resimden 2.
    • Adjust the two 1.5 mm flat head prism screws by slightly turning the driver.
    • Note: Look through the binoculars after each turn, and if the vision is aligned, you can stop at this step. If adjusting these screws does not align the vision, proceed to Step 9.
    • DO NOT tighten the prism screws too much, or you will crack the prism and permanently destroy it. Repairing or replacing the prism is beyond the scope of this guide.
  9. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 9, 1 resimden 1.
    • Unscrew the two front objective lenses by hand.
  10. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 10, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 10, 2 resimden 2.
    • Unscrew the two J0 head front screws.
  11. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 11, 1 resimden 1.
    • Remove the two front plates.
  12. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 12, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 12, 2 resimden 2.
    • Peel back the front rubber coverings on both sides.
  13. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 13, 2 resimden 1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: adım 13, 2 resimden 2.
    • Adjust the two front 1.5 mm flat head prism screws with small turns.
    • Look through the binoculars after each adjustment to see if it is aligning the vision, and repeat the adjustments until it is repaired.
    • You may need to return to Step 8 to fine-tune the other set of screws. All four prism adjustment screws must be in their correct positions to produce the correct view through the binoculars.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
James Silva
241 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G3, Bruce Fall 2019 CSU Fullerton, Team S1-G3, Bruce Fall 2019 üyesi
CSUF-BRUCE-F19S1G3
4 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 40
Son 30 gün: 152
Her zaman: 5,601
