Ana içeriğe geç
How to Repair Frayed Shoelaces
Neye ihtiyacın var
  1. How to Repair Frayed Shoelaces, How to Repair Frayed Shoelaces: adım 1, 1 resimden 1.
    • Cut of the excess frayed shoelace.
  2. How to Repair Frayed Shoelaces: adım 2, 3 resimden 1. How to Repair Frayed Shoelaces: adım 2, 3 resimden 2. How to Repair Frayed Shoelaces: adım 2, 3 resimden 3.
    • Slip the entire heat shrink tube over the frayed part of the lace.
    • Make sure to clump the frayed part of the lace together when inserting the tubing.
    • Do not cover too much of the lace that is not frayed with tubing as that could result in unwanted indents in the shoelace.
  3. How to Repair Frayed Shoelaces: adım 3, 2 resimden 1. How to Repair Frayed Shoelaces: adım 3, 2 resimden 2.
    • After slipping the tube on, grab the scissors and trim the excess tubing to the length of your satisfaction.
    • Remember not to go beyond the frayed part of the lace with tubing.
  4. How to Repair Frayed Shoelaces: adım 4, 3 resimden 1. How to Repair Frayed Shoelaces: adım 4, 3 resimden 2. How to Repair Frayed Shoelaces: adım 4, 3 resimden 3.
    • Now use the lighter and heat the heat shrink tube, about an inch away from the lace, until the tube becomes compressed all the way around.
    • Make sure to heat the heat shrink tube all the way around, heating the entire tube
    • When heating, always keep moving the lighter all around and not staying on one part of the tube for too long.
  5. How to Repair Frayed Shoelaces: adım 5, 1 resimden 1.
    • Repeat these steps on all the other frayed shoelaces.
Sonuç
When the heat shrink tube is completely shrunk to appropriate size, you are finished. Repeat steps 1-4 depending on how many frayed laces are present.
14 farklı kişi bu kılavuzu tamamladı.
Anirudh Jain
605 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 28-6, Green Spring 2015 Cal Poly, Team 28-6, Green Spring 2015 üyesi
CPSU-GREEN-S15S28G6
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 12,472
