Ana içeriğe geç
How to Repair Hook Earrings
Neye ihtiyacın var
  1. How to Repair Hook Earrings, How to Repair Hook Earrings: adım 1, 3 resimden 1. How to Repair Hook Earrings, How to Repair Hook Earrings: adım 1, 3 resimden 2. How to Repair Hook Earrings, How to Repair Hook Earrings: adım 1, 3 resimden 3.
    • Clean both the hook and earring with hydrogen peroxide to ensure that there are no germs, dust, or other particles on the pieces.
  2. How to Repair Hook Earrings: adım 2, 3 resimden 1. How to Repair Hook Earrings: adım 2, 3 resimden 2. How to Repair Hook Earrings: adım 2, 3 resimden 3.
    • In one hand, hold the hook in place.
    • Use pliers to gently pull open the small loop at the base of the hook.
  3. How to Repair Hook Earrings: adım 3, 3 resimden 1. How to Repair Hook Earrings: adım 3, 3 resimden 2. How to Repair Hook Earrings: adım 3, 3 resimden 3.
    • Carefully insert the open loop on the hook through the loop on the earring.
    • If your earring has a designated front and back, ensure that the front of the earring is facing away from the tip of the hook.
  4. How to Repair Hook Earrings: adım 4, 2 resimden 1. How to Repair Hook Earrings: adım 4, 2 resimden 2.
    • Use pliers to close the loop by clamping down on the open end of the loop and the base of the hook, pushing them towards one another.
    • If done correctly, the loop should be a complete circle.
  5. How to Repair Hook Earrings: adım 5, 1 resimden 1.
    • Rotate the loop so that the pliers are touching both sides of the completed circle.
    • Gently clamp down.
    • This step ensures that the loop is completely closed with no gaps.
  6. How to Repair Hook Earrings: adım 6, 1 resimden 1.
    • You're done! Congratulations on repairing your hook earrings!
Sonuç
To reassemble your earring properly, please complete these instructions in numerical order. Earrings can be extremely delicate, so make sure you are being gentle in each step. If you accidentally reattach the earring backwards, simply go back to step two and reopen the loop. If followed correctly, you will officially know how to reattach a hook to an earring!
Anna
183 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 103
