Ana içeriğe geç
How to Repair LP Record Playing Surface
Neye ihtiyacın var
  1. How to Repair LP Record Playing Surface, How to Repair LP Record Playing Surface: adım 1, 1 resimden 1.
    • Create a solution of 2 parts water to 1 part rubbing alcohol.
    • Using a paper towel, lightly brush the record with this solution.
  2. How to Repair LP Record Playing Surface: adım 2, 1 resimden 1.
    • Apply enough wood glue to cover the record's surface.
  3. How to Repair LP Record Playing Surface: adım 3, 1 resimden 1.
    • Place the record on a record player, then turn on the record player so it rotates.
    • With a note card, apply the wood glue so that it covers the entire record surface.
    • Avoid getting glue on the record's label, as this will damage the label once the glue dries.
  4. How to Repair LP Record Playing Surface: adım 4, 1 resimden 1.
    • Place a strip of tape on the wet wood glue.
    • This will act as a handle later to remove the dried wood glue.
  5. How to Repair LP Record Playing Surface: adım 5, 1 resimden 1.
    • Turn the record player off after you apply the wood glue.
    • Let the record sit for 12 hours to dry.
  6. How to Repair LP Record Playing Surface: adım 6, 1 resimden 1.
    • After 12 hours, check to see the wood glue has dried.
    • If it has dried, use the tape as a “handle” to peel the glue off.
    • If the wood glue is not yet dry, check back once every hour until it has dried.
  7. How to Repair LP Record Playing Surface: adım 7, 1 resimden 1.
    • Repeat steps 1-6 on the opposite side of the LP if necessary.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 2,452
