Ana içeriğe geç
How to Repair Scratched Eyeglass Lenses
Neye ihtiyacın var
  1. How to Repair Scratched Eyeglass Lenses, How to Repair Scratched Eyeglass Lenses: adım 1, 3 resimden 1. How to Repair Scratched Eyeglass Lenses, How to Repair Scratched Eyeglass Lenses: adım 1, 3 resimden 2. How to Repair Scratched Eyeglass Lenses, How to Repair Scratched Eyeglass Lenses: adım 1, 3 resimden 3.
    • Place the eyeglasses, wax, and cloth on a flat surface.
  2. How to Repair Scratched Eyeglass Lenses: adım 2, 2 resimden 1. How to Repair Scratched Eyeglass Lenses: adım 2, 2 resimden 2.
    • Remove any dirt or debris stuck to the lenses with a soft cleaning cloth.
    • Clean glasses gently; using excessive force can grind dirt into lenses and cause more scratches.
  3. How to Repair Scratched Eyeglass Lenses: adım 3, 3 resimden 1. How to Repair Scratched Eyeglass Lenses: adım 3, 3 resimden 2. How to Repair Scratched Eyeglass Lenses: adım 3, 3 resimden 3.
    • Dab some vehicle wax on the scratched area of the lens.
  4. How to Repair Scratched Eyeglass Lenses: adım 4, 3 resimden 1. How to Repair Scratched Eyeglass Lenses: adım 4, 3 resimden 2. How to Repair Scratched Eyeglass Lenses: adım 4, 3 resimden 3.
    • Buff wax into lens with a lint-free cloth using small, circular motions until the scratch is gone. This can take up to 5 minutes.
    • For especially deep scratches, you may need to re-apply wax and buff multiple times.
    • You may need multiple cloths, as the wax sticks to the cloth easily.
  5. How to Repair Scratched Eyeglass Lenses: adım 5, 3 resimden 1. How to Repair Scratched Eyeglass Lenses: adım 5, 3 resimden 2. How to Repair Scratched Eyeglass Lenses: adım 5, 3 resimden 3.
    • Using lukewarm water, rinse off glasses for 10-15 seconds to remove any additional wax.
    • To dry off glasses and remove any remaining wax on the lenses, wipe them off using a clean cloth.
Sonuç
For particularly deep or persistent scratches, repeat these steps until the scratch is repaired.
56 farklı kişi bu kılavuzu tamamladı.
Andrew Rose
2.163 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G5
5 Üyeler
32 adet Kılavuz yazıldı
24 Yorum
thank you, i have a scratched lens and will try this. cheers.
amackay5 - Yanıt
Stupid is as stupid does! Think about it. A scratch is a certain width, when you polish it you are just grinding off the edges of the scratch and actually making it wider. So unless you are capable of removing all the surrounding material to the depth of the deepest part of the scratch AND maintaining the profile to within a very very small tolerance then this just WILL NOT work. Filling the scratch with wax cannot work either as wax does not have the same refractive index as the lens material. Conclusion: take care of your glasses and if you are careless enough to damage them it's your own fault, accept responsibility and replace them.
abscomm - Yanıt
This sounds like "I've not tried this but I've thought about it for a few minutes and this is what I think will happen". Very short on evidence.
steve -
Wow!!! Just couldn’t help yourself could you. Perhaps you’ve heard “If you can’t say something nice say nothing at all”! Grow up without doing it at someone elses expense.
Yaya -
Obviously, this person has never made a mistake and is absolutely perfect in every way.
Stuart Conner -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 91
Son 7 gün: 465
Son 30 gün: 2,395
Her zaman: 232,482
