Ana içeriğe geç
How to Repair a Broken 3-Wick Jar Candle
Neye ihtiyacın var
  1. How to Repair a Broken 3-Wick Jar Candle, How to Repair a Broken 3-Wick Jar Candle: adım 1, 3 resimden 1. How to Repair a Broken 3-Wick Jar Candle, How to Repair a Broken 3-Wick Jar Candle: adım 1, 3 resimden 2. How to Repair a Broken 3-Wick Jar Candle, How to Repair a Broken 3-Wick Jar Candle: adım 1, 3 resimden 3.
    • Cut the candle wax into small cubes and remove the wicks.
    • The smaller the cubes are, the faster they will melt later.
    • Be careful when cutting near the wick so you don't accidentally cut the wick.
  2. How to Repair a Broken 3-Wick Jar Candle: adım 2, 1 resimden 1.
    • Put the pieces of candle wax into a large bowl.
    • Choose a heat resistant bowl large enough to sit on top of a cooking pot.
  3. How to Repair a Broken 3-Wick Jar Candle: adım 3, 1 resimden 1.
    • Boil 350-400mL water in a medium pot.
    • You may start by boiling the water on high heat, but be sure to turn it down to medium once it begins to boil.
  4. How to Repair a Broken 3-Wick Jar Candle: adım 4, 1 resimden 1.
    • Place the bowl on top of the pot.
    • If you need to handle the bowl or cooking pot, use a pair of oven mitts or pot holders.
  5. How to Repair a Broken 3-Wick Jar Candle: adım 5, 2 resimden 1. How to Repair a Broken 3-Wick Jar Candle: adım 5, 2 resimden 2.
    • Melt the wax over medium heat and stir frequently with a wooden spoon until all the candle wax completely melts.
  6. How to Repair a Broken 3-Wick Jar Candle: adım 6, 1 resimden 1.
    • Place the wicks into glass jars, and secure the candle wicks by sticking the wick taps to bottom of the jars.
    • You should place your wicks in the middle of the glasses. An improperly centered wick will burn your candle unevenly later, and it is likely to leave soot on the side of the glass.
  7. How to Repair a Broken 3-Wick Jar Candle: adım 7, 1 resimden 1.
    • Using a pair of oven mitts or pot holders, pour the melted wax into the glass jars.
    • Do not touch the bowl directly while you pour your melted candle wax into the glasses. The bowl is hot and there is a burn risk.
  8. How to Repair a Broken 3-Wick Jar Candle: adım 8, 1 resimden 1.
    • Let the jars sit at room temperature and wait until they are completely dry.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Giang Dao
157 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team 2-13, O'Regan Fall 2021 York University, Team 2-13, O'Regan Fall 2021 üyesi
YORK-O'REGAN-F21S2G13
1 Üye
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 2,413
