Ana içeriğe geç
How to Repair a Broken Huggie Earring Clasp
Neye ihtiyacın var
  1. How to Repair a Broken Huggie Earring Clasp, How to Repair a Broken Huggie Earring Clasp: adım 1, 1 resimden 1.
    • Clean the post and clasp of the earring with a dry cloth.
  2. How to Repair a Broken Huggie Earring Clasp: adım 2, 2 resimden 1. How to Repair a Broken Huggie Earring Clasp: adım 2, 2 resimden 2.
    • Close the earring and note where the main post hits the notch on the opposite side.
    • There are two notches, one on the main post and one on the opposite side of the earring.
  3. How to Repair a Broken Huggie Earring Clasp: adım 3, 1 resimden 1.
    • Mark this spot with a writing instrument (optional).
  4. How to Repair a Broken Huggie Earring Clasp: adım 4, 1 resimden 1.
    • Re-open the earring.
  5. How to Repair a Broken Huggie Earring Clasp: adım 5, 3 resimden 1. How to Repair a Broken Huggie Earring Clasp: adım 5, 3 resimden 2. How to Repair a Broken Huggie Earring Clasp: adım 5, 3 resimden 3.
    • Ensure the post is lined up with the opposite notch. If not, gently bend it with your finger until it is in a suitable position.
  6. How to Repair a Broken Huggie Earring Clasp: adım 6, 1 resimden 1.
    • Grip the earring post with a small plier or tweezer and push the post slightly upward.
  7. How to Repair a Broken Huggie Earring Clasp: adım 7, 2 resimden 1. How to Repair a Broken Huggie Earring Clasp: adım 7, 2 resimden 2.
    • Open to check if the earring clicks.
  8. How to Repair a Broken Huggie Earring Clasp: adım 8, 1 resimden 1.
    • If the earring isn’t clicking, push the post further upward using pliers.
    • Adjust, then check again.
  9. How to Repair a Broken Huggie Earring Clasp: adım 9, 1 resimden 1.
    • If the earring clicks but is hard to open, push the post downward using pliers.
    • This is an adjustment process, so make small adjustments until it is restored.
  10. How to Repair a Broken Huggie Earring Clasp: adım 10, 1 resimden 1.
    • Make final adjustments until the huggie clasp clicks and the earring closes securely.
    • Wipe the marker off of your earring.
Sonuç
Your earring is now fixed! If the post bends again, repeat the same steps to repair.
Hana Ito
181 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-6, Whithaus Spring 2024 UC Davis, Team 4-6, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S4G6
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 153
