Ana içeriğe geç
How to Repair a Broken Jump Ring
Neye ihtiyacın var
  1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: adım 1, 1 resimden 1.
    • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
    • Make sure that the ring's opening is not blocked by the pliers.
  2. How to Repair a Broken Jump Ring: adım 2, 1 resimden 1.
    • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
  3. How to Repair a Broken Jump Ring: adım 3, 1 resimden 1.
    • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
  4. How to Repair a Broken Jump Ring: adım 4, 2 resimden 1. How to Repair a Broken Jump Ring: adım 4, 2 resimden 2.
    • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
  5. How to Repair a Broken Jump Ring: adım 5, 2 resimden 1. How to Repair a Broken Jump Ring: adım 5, 2 resimden 2.
    • Insert your earring into the opening of the jump ring.
  6. How to Repair a Broken Jump Ring: adım 6, 2 resimden 1. How to Repair a Broken Jump Ring: adım 6, 2 resimden 2.
    • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
    • Make sure that the gap is closed tight!
Sonuç
Your earrings are ready to be worn again!
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 996
