Ana içeriğe geç
How to Repair a Broken Kitchen Faucet Pull-out Spray Head
Neye ihtiyacın var
  1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: adım 1, 2 resimden 1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head, Kitchen Faucet Pull-out Spray Head: adım 1, 2 resimden 2.
    • Located underneath the sink is the water-control valve.
    • Shut off the water supply by turning the water-control valve.
    • Not all water control values are the same so some nozzles may vary.
  2. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 2, 3 resimden 1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 2, 3 resimden 2. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 2, 3 resimden 3.
    • Pull on the kitchen spray head nozzle to reveal the connected hose.
    • Unscrew the kitchen faucet spray head nozzle counterclockwise off of the hose assembly.
  3. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 3, 2 resimden 1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 3, 2 resimden 2.
    • Remove the rubber gasket from the hose to reveal the c-clip.
    • Remove the c-clip that is located on the pull-out sprayer connection point with a small flat head screwdriver.
    • Do not discard the gasket. It can be reused unless damaged.
  4. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 4, 2 resimden 1. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 4, 2 resimden 2.
    • Pull on the sink faucet spray head from above the sink to find the main hose connection point to the water line located underneath the sink.
    • Unscrew the hose from the main faucet’s water line connection point.
    • A wrench may be necessary in order to loosen the nut.
    • Remove the hose from the sink sprayer location.
    • Connect the new hose by pressing it into the connection point. Then screw hose back on clockwise.
    • A wrench may be necessary in order to secure the end of the hose to the nut.
  5. How to Repair a Broken Kitchen Faucet Pull-out Spray Head: adım 5, 1 resimden 1.
    • Apply plumber's tape to the male threads on the new sink sprayer head to avoid leakage.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jodi Wright
158 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 26-2, Rauch Spring 2016 Texas Tech, Team 26-2, Rauch Spring 2016 üyesi
TTU-RAUCH-S16S26G2
2 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 14,049
