Ana içeriğe geç
How to Repair a Broken Plant Stem
Neye ihtiyacın var
  1. How to Repair a Broken Plant Stem, How to Repair a Broken Plant Stem: adım 1, 1 resimden 1.
    • Determine whether the stem is completely severed or still attached by some connective tissue.
    • If the stem is bent, but still attached, the connective tissue helps the regrowth process and you may proceed to the following steps.
    • If the stem is completely severed, the following steps will not work.
  2. How to Repair a Broken Plant Stem: adım 2, 1 resimden 1.
    • Place the support stick securely in the soil next to the broken stem.
    • Make sure the stick you choose is similar in size to the plant stem.
  3. How to Repair a Broken Plant Stem: adım 3, 1 resimden 1.
    • Gently position the stem upright along the stick.
  4. How to Repair a Broken Plant Stem: adım 4, 1 resimden 1.
    • Measure the garden tie tape around the stick and broken stem.
    • Cut tape to a desired length using scissors.
    • Twine or garden wire can be used as a replacement of graden tie tape.
  5. How to Repair a Broken Plant Stem: adım 5, 2 resimden 1. How to Repair a Broken Plant Stem: adım 5, 2 resimden 2.
    • Securely tie a double knot around the stem and the stick.
    • Make sure to keep the knot loose enough to leave room for air circulation and plant growth.
  6. How to Repair a Broken Plant Stem: adım 6, 1 resimden 1.
    • Remove or prune the dead leaves from the pot.
    • This will ensure that the nutrients goes to the recovering stem instead of the dead members.
  7. How to Repair a Broken Plant Stem: adım 7, 1 resimden 1.
    • Place the plant in extra nutrient filled soil for the plant to heal.
  8. How to Repair a Broken Plant Stem: adım 8, 1 resimden 1.
    • Continue to monitor the plant everyday.
    • Water the plant as needed.
    • Pay special attention to the broken area to make sure there is no mold development.
Sonuç
Zeeann McCarty
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-5, Andersen Winter 2023 UC Davis, Team 3-5, Andersen Winter 2023 üyesi
UCD-ANDERSEN-W23S3G5
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 62
Son 7 gün: 524
Son 30 gün: 1,913
Her zaman: 9,105
