Ana içeriğe geç
How to Repair a Broken Windowsill
Neye ihtiyacın var
  1. How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: adım 1, 3 resimden 1. How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: adım 1, 3 resimden 2. How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: adım 1, 3 resimden 3.
    • Remove any loose, splintered, or jagged wood by hand.
  2. How to Repair a Broken Windowsill: adım 2, 3 resimden 1. How to Repair a Broken Windowsill: adım 2, 3 resimden 2. How to Repair a Broken Windowsill: adım 2, 3 resimden 3.
    • Grab three straight sections of cardboard.
    • Apply Vaseline to one side of each section of cardboard by hand. Vaseline will prevent the wood filler from sticking to the cardboard.
  3. How to Repair a Broken Windowsill: adım 3, 1 resimden 1.
    • Hold one section of cardboard underneath the corner needing repair with the Vaseline side facing up.
  4. How to Repair a Broken Windowsill: adım 4, 2 resimden 1. How to Repair a Broken Windowsill: adım 4, 2 resimden 2.
    • Apply wood filler to the corner by squeezing the tube.
  5. How to Repair a Broken Windowsill: adım 5, 3 resimden 1. How to Repair a Broken Windowsill: adım 5, 3 resimden 2. How to Repair a Broken Windowsill: adım 5, 3 resimden 3.
    • Position the other two sections of cardboard on either side of the corner to help shape the filler into a right angle. Place the sides with the Vaseline on them toward the filler.
    • Use a putty knife or plastic butter knife to smooth filler if needed.
  6. How to Repair a Broken Windowsill: adım 6, 1 resimden 1.
    • Remove the cardboard sections before the filler dries completely.
    • Allow the filler to dry for approximately six hours. The filler may take less time to dry if repairing a smaller section of the apron. For dime sized reparations, the filler will take approximately two hours to dry.
  7. How to Repair a Broken Windowsill: adım 7, 2 resimden 1. How to Repair a Broken Windowsill: adım 7, 2 resimden 2.
    • Sand the filler with 120 grit sandpaper until it is satisfactory.
    • Repeat steps 4-7 if the corner is not the desired shape.
  8. How to Repair a Broken Windowsill: adım 8, 2 resimden 1. How to Repair a Broken Windowsill: adım 8, 2 resimden 2.
    • Paint the finished corner with the desired shade of paint.
    • Allow the paint 3 hours to completely dry.
Sonuç
Once the paint dries, the project is complete.
Julia Byrd
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 48
Son 30 gün: 256
Her zaman: 5,504
