Ana içeriğe geç
How to Repair a Broken/Cracked Soccer Shin Pad
Neye ihtiyacın var
  1. How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: adım 1, 3 resimden 1. How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: adım 1, 3 resimden 2. How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: adım 1, 3 resimden 3.
    • Start by properly cleaning the dirt off the soccer shin pad with a coarse brush.
    • Be sure to clear any dust from inside the crack as well, as any dirt left inside can interfere with the bonding agent
  2. How to Repair a Broken/Cracked Soccer Shin Pad: adım 2, 1 resimden 1.
    • Put one clamp on either side of the crack.
  3. How to Repair a Broken/Cracked Soccer Shin Pad: adım 3, 1 resimden 1.
    • Align the clamps so that there are no spaces throughout the crack.
  4. How to Repair a Broken/Cracked Soccer Shin Pad: adım 4, 2 resimden 1. How to Repair a Broken/Cracked Soccer Shin Pad: adım 4, 2 resimden 2.
    • Make sure clamps are aligned with the crack before you apply the resin solution
    • Apply the resin solution onto the crack, being sure to fully cover the crack on both sides.
    • Let the solution dry for at least 30 minutes.
    • But we suggest leaving the shin pad out for 24 hours for best results.
  5. How to Repair a Broken/Cracked Soccer Shin Pad: adım 5, 3 resimden 1. How to Repair a Broken/Cracked Soccer Shin Pad: adım 5, 3 resimden 2. How to Repair a Broken/Cracked Soccer Shin Pad: adım 5, 3 resimden 3.
    • Remove the clamps slowly so that no damage will be done to the shin pad.
  6. How to Repair a Broken/Cracked Soccer Shin Pad: adım 6, 2 resimden 1. How to Repair a Broken/Cracked Soccer Shin Pad: adım 6, 2 resimden 2.
    • Clean the extra resin solution that sits on top of the shin pad.
    • Your shin pad is now ready to use.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 286
