Ana içeriğe geç
How to Repair a Chip in Laminate Flooring
Neye ihtiyacın var
    1. How to Repair a Chip in Laminate Flooring, How to Repair a Chip in Laminate Flooring: adım 1, 1 resimden 1.
      • Wipe the chipped area with a damp cloth to remove dust and debris.
      • A clean surface helps the repair compound adhere better and ensures a smoother finish.
      FixBot'a Sor
      Yorum Ekle
    2. How to Repair a Chip in Laminate Flooring: adım 2, 3 resimden 1. How to Repair a Chip in Laminate Flooring: adım 2, 3 resimden 2. How to Repair a Chip in Laminate Flooring: adım 2, 3 resimden 3.
      • Use a knife to cut off enough wood putty to completely fill the chipped area.
      FixBot'a Sor
      Yorum Ekle
    3. How to Repair a Chip in Laminate Flooring: adım 3, 2 resimden 1. How to Repair a Chip in Laminate Flooring: adım 3, 2 resimden 2.
      • Knead the putty for 2 minutes until it reaches a smooth and consistent texture.
      FixBot'a Sor
      Yorum Ekle
    4. How to Repair a Chip in Laminate Flooring: adım 4, 2 resimden 1. How to Repair a Chip in Laminate Flooring: adım 4, 2 resimden 2.
      • Press the putty firmly and evenly to fill the chipped area.
      FixBot'a Sor
      Yorum Ekle
    5. How to Repair a Chip in Laminate Flooring: adım 5, 2 resimden 1. How to Repair a Chip in Laminate Flooring: adım 5, 2 resimden 2.
      • Use a damp cloth to smooth the area before the putty hardens.
      • Allow the putty to set for 30–60 minutes before continuing to the next step.
      FixBot'a Sor
      Yorum Ekle
    6. How to Repair a Chip in Laminate Flooring: adım 6, 2 resimden 1. How to Repair a Chip in Laminate Flooring: adım 6, 2 resimden 2.
      • Prepare matching color repair compound in a small container.
      FixBot'a Sor
      Yorum Ekle
    7. How to Repair a Chip in Laminate Flooring: adım 7, 2 resimden 1. How to Repair a Chip in Laminate Flooring: adım 7, 2 resimden 2.
      • Apply the color to the repaired area with a brush and spread it evenly for full coverage.
      • Use gentle, precise brush strokes to blend the repair naturally with the surrounding flooring.
      FixBot'a Sor
      Yorum Ekle
    8. How to Repair a Chip in Laminate Flooring: adım 8, 2 resimden 1. How to Repair a Chip in Laminate Flooring: adım 8, 2 resimden 2.
      • Clean the area around the repair to remove excess material and ensure a polished finish.
      • Allow the area to dry for 6–12 hours before walking on it or making any touchups.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repairing chips in laminate flooring doesn’t have to be hard or costly. With minimal effort, this repaired flooring looks renewed, lasts longer, and provides a practical solution for everyday wear and tear.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 41
Son 30 gün: 177
Her zaman: 1,728
