Ana içeriğe geç
How to Repair a Crack on a Vittorazi Moster Exhaust
Neye ihtiyacın var
  1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: adım 1, 3 resimden 1. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: adım 1, 3 resimden 2. How to Repair a Crack on a Vittorazi Moster Exhaust, How to Repair a Crack on a Vittorazi Moster Exhaust: adım 1, 3 resimden 3.
    • Use a 10mm open wrench to lossen the three exhaust mounting points.
    • Locate the nuts that need to be adjusted and make sure you you have the proper tools, stated earlier to ensure they can loosen.
    • Once you have found the nuts, use your 10mm wrench to carefully unscrew and loosen the nuts.
    • This may take some extra force to loosen the nuts, and if this is case, keep in mind all safety precautions.
  2. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 5, 2 resimden 1. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 5, 2 resimden 2.
    • Remove with the 10mm wrench the two nuts in the exhaust base.
  3. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 6, 1 resimden 1.
    • Remove the loosen mounts and take out the exhaust with it's base.
  4. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 7, 1 resimden 1.
    • Clean the cracked area with alcohol and a rug.
  5. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 8, 2 resimden 1. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 8, 2 resimden 2.
    • Grind the cracked area with the grinder.
  6. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 9, 2 resimden 1. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 9, 2 resimden 2.
    • Weld the cracked area with the welder.
  7. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 10, 2 resimden 1. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 10, 2 resimden 2.
    • Grind the welded area with the grinder to smooth the area.
  8. How to Repair a Crack on a Vittorazi Moster Exhaust: adım 11, 1 resimden 1.
    • Reinstall the exhaust to the motor by repeating 1-3 steps in reverse order.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 1,200
