Ana içeriğe geç
How to Repair a Cracked Mirror
Neye ihtiyacın var
  1. How to Repair a Cracked Mirror, How to Repair a Cracked Mirror: adım 1, 1 resimden 1.
    • Clean the mirror with soap and water.
  2. How to Repair a Cracked Mirror: adım 2, 3 resimden 1. How to Repair a Cracked Mirror: adım 2, 3 resimden 2. How to Repair a Cracked Mirror: adım 2, 3 resimden 3.
    • Remove the adhesive backing of the stabilizer film.
    • Press the stabilizer film over the crack.
    • Use your fingers to smooth out the stabilizer film.
  3. How to Repair a Cracked Mirror: adım 3, 1 resimden 1.
    • Fill the syringe with epoxy resin.
  4. How to Repair a Cracked Mirror: adım 4, 2 resimden 1. How to Repair a Cracked Mirror: adım 4, 2 resimden 2.
    • Insert the tip of the syringe through the stabilizer film.
    • Push down the plunger to fill the crack with resin.
  5. How to Repair a Cracked Mirror: adım 5, 1 resimden 1.
    • Set a timer for 20 mins and wait for the resin to harden.
  6. How to Repair a Cracked Mirror: adım 6, 1 resimden 1.
    • Peel off the stabilizer film.
  7. How to Repair a Cracked Mirror: adım 7, 2 resimden 1. How to Repair a Cracked Mirror: adım 7, 2 resimden 2.
    • Add a drop of resin over the crack.
    • Cover the resin with the curing film.
  8. How to Repair a Cracked Mirror: adım 8, 1 resimden 1.
    • Set a timer for 1 hour and wait for the resin to cure.
  9. How to Repair a Cracked Mirror: adım 9, 2 resimden 1. How to Repair a Cracked Mirror: adım 9, 2 resimden 2.
    • Remove the curing film.
    • Scrape away any excess resin using the razor blade.
    • Use caution when handling the razor blade as you do not want to cut yourself during the process.
  10. How to Repair a Cracked Mirror: adım 10, 1 resimden 1.
    • Clean the area with glass cleaner.
Sonuç
Marriam Shaikh
181 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 47
Son 30 gün: 217
Her zaman: 961
