Ana içeriğe geç
How to Repair a Damaged Steelcase Cachet Chair Armrest
Neye ihtiyacın var
  1. How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 1, 3 resimden 1. How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 1, 3 resimden 2. How to Repair a Damaged Steelcase Cachet Chair Armrest, How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 1, 3 resimden 3.
    • Use an iFixit Opening Tool to remove the broken piece from your cracked armrest.
    • Avoid the jagged edges of plastic as they are sharp and could cut or scrape the skin.
  2. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 2, 2 resimden 1. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 2, 2 resimden 2.
    • Use sandpaper to lightly sand the edges of the broken piece of arm rest.
    • Remove any remaining debris from the armrest.
  3. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 3, 2 resimden 1. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 3, 2 resimden 2.
    • Wear gloves! The putty is toxic!
    • Cut or pull off a small section of putty.
    • Knead the putty in your hands for 30-60 seconds until it is a uniform color.
  4. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 4, 1 resimden 1.
    • Work quickly! The putty will begin to harden in 5 minutes!
    • Apply a small amount of putty on the inside of the hollow space of the armrest.
    • The putty will act as a support for the broken piece.
    • Repeat Step 3 to use as many pieces of putty as needed.
  5. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 5, 1 resimden 1.
    • Apply putty along the edges of the broken piece.
  6. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 6, 2 resimden 1. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 6, 2 resimden 2.
    • Set the broken piece back onto the armrest.
    • Try to make the broken piece level with the rest of the armrest, as this will make Steps 7 & 8 easier.
    • Let the putty dry for about 10 minutes.
  7. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 7, 2 resimden 1. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 7, 2 resimden 2.
    • Apply the plastic putty over the broken piece.
    • Press putty into any remaining empty spaces.
    • Repeat Step 3 as many times as needed.
    • Let the putty dry for 10 minutes in between applications.
  8. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 8, 2 resimden 1. How to Repair a Damaged Steelcase Cachet Chair Armrest: adım 8, 2 resimden 2.
    • Sand down the putty covering to make the surface smooth and level with the armrest.
    • Paint-match the color of the chair and paint over the putty for a cosmetically seamless result.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Henry Xu
169 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-5, Whithaus Spring 2024 UC Davis, Team 4-5, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S4G5
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 270
