Giriş
This guide will teach you to repair a Fastmark armband machine in the case of a jam. This machine is used in the emergency room at certain hospitals to print patient armbands. No prior knowledge is needed for this repair. The only item that may be required for this repair is a new roll of armbands. The steps are simple and require you to open the machine, mix the current jam or issue and then close the machine.
Open the machine by lifting the right side up.
Repeat these steps if the text is not lined up in the correct place on the armband.
2 farklı kişi bu kılavuzu tamamladı.
