Ana içeriğe geç
How to Repair a Hole in the Wall Using Spackle
Neye ihtiyacın var
  1. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: adım 1, 3 resimden 1. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: adım 1, 3 resimden 2. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: adım 1, 3 resimden 3.
    • Prepare the damaged surface by cleaning and removing all dust and debris.
    • If the surface has a wallpaper, remove it for a length more extensive than the mesh patch.
    FixBot'a Sor
    Yorum Ekle
  2. How to Repair a Hole in  the Wall Using Spackle: adım 2, 3 resimden 1. How to Repair a Hole in  the Wall Using Spackle: adım 2, 3 resimden 2. How to Repair a Hole in  the Wall Using Spackle: adım 2, 3 resimden 3.
    • Apply the self-Adhesive patch by peeling back the paper liner from the patch and apply it over the hole.
    • Press patch firmly to ensure a strong bond to the wall.
    FixBot'a Sor
    Yorum Ekle
  3. How to Repair a Hole in  the Wall Using Spackle: adım 3, 3 resimden 1. How to Repair a Hole in  the Wall Using Spackle: adım 3, 3 resimden 2. How to Repair a Hole in  the Wall Using Spackle: adım 3, 3 resimden 3.
    • Open container and mix spackling compound before applying.
    • Mix thoroughly to have a smooth application.
    FixBot'a Sor
    Yorum Ekle
  4. How to Repair a Hole in  the Wall Using Spackle: adım 4, 3 resimden 1. How to Repair a Hole in  the Wall Using Spackle: adım 4, 3 resimden 2. How to Repair a Hole in  the Wall Using Spackle: adım 4, 3 resimden 3.
    • Use the putty knife to spread spackling compound evenly over the adhesive patch.
    • Spread the spackling mixture beyond the area intended to cover.
    • Apply thinner layers toward the edges of the patch, so the patched area blends with the wall.
    FixBot'a Sor
    Yorum Ekle
  5. How to Repair a Hole in  the Wall Using Spackle: adım 5, 2 resimden 1. How to Repair a Hole in  the Wall Using Spackle: adım 5, 2 resimden 2.
    • Allow the compound to dry completely before moving to the last step.
    • Depending on the hole's size and thickness of the layers applied, it might take a while to dry.
    FixBot'a Sor
    Yorum Ekle
  6. How to Repair a Hole in  the Wall Using Spackle: adım 6, 3 resimden 1. How to Repair a Hole in  the Wall Using Spackle: adım 6, 3 resimden 2. How to Repair a Hole in  the Wall Using Spackle: adım 6, 3 resimden 3.
    • Once the spackling compound has dried, sand it lightly with a sand pad/sponge.
    • Smooth out any bumps on the surface.
    • Do not sand down to mesh patch.
    • Once the surface is smooth, paint, wallpaper, or apply any texture desire.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 43
Son 30 gün: 366
Her zaman: 8,046
