Ana içeriğe geç
How to Repair a Hole in Workout/Yoga Around the Groin
Neye ihtiyacın var
  1. How to Repair a Hole in Workout/Yoga Around the Groin, How to Repair a Hole in Workout/Yoga Around the Groin: adım 1, 1 resimden 1.
    • Take the pants and put them inside out.
    • You want the seams to be showing.
  2. How to Repair a Hole in Workout/Yoga Around the Groin: adım 2, 1 resimden 1.
    • Take the sewing pins (if the hole is big) and pin closed along the seam.
    • This should take no more than 5 pins to do.
  3. How to Repair a Hole in Workout/Yoga Around the Groin: adım 3, 3 resimden 1. How to Repair a Hole in Workout/Yoga Around the Groin: adım 3, 3 resimden 2. How to Repair a Hole in Workout/Yoga Around the Groin: adım 3, 3 resimden 3.
    • Take the thread (make sure it is the preferred color that matches the pants) and thread it through the needle.
    • Make sure to leave a large tail at least 20 inches.
    • Tie the two ends together into a small knot.
  4. How to Repair a Hole in Workout/Yoga Around the Groin: adım 4, 1 resimden 1.
    • Insert the needle into the fabric from one side until you can see the needle on the other side.
    • Pull all the way through.
  5. How to Repair a Hole in Workout/Yoga Around the Groin: adım 5, 1 resimden 1.
    • Take the needle and put it back through the fabric a short distance from where it came out originally.
  6. How to Repair a Hole in Workout/Yoga Around the Groin: adım 6, 1 resimden 1.
    • Continue steps 7 and 8 until you have reached the other end of the hole.
  7. How to Repair a Hole in Workout/Yoga Around the Groin: adım 7, 2 resimden 1. How to Repair a Hole in Workout/Yoga Around the Groin: adım 7, 2 resimden 2.
    • Once you have finished sewing the hole, take the thread and tie a small knot at the base of the thread.
    • Cut thread and reverse the pants to check the seam.
  8. How to Repair a Hole in Workout/Yoga Around the Groin: adım 8, 1 resimden 1.
    • If seam is completely closed, then you have done it!
    • If not, then repeat steps 7-11 until hole is completely closed.
Sonuç
If seam is completely closed, then you have done it! If not, then repeat steps 7-11 until hole is completely closed.
Jessy Sternblitz
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 116
