Ana içeriğe geç
How to Repair a Hole in a Duvet Insert
Neye ihtiyacın var
  1. How to Repair a Hole in a Duvet Insert, How to Repair a Hole in a Duvet Insert: adım 1, 1 resimden 1.
    • Remove the duvet cover from the insert and locate the hole.
  2. How to Repair a Hole in a Duvet Insert: adım 2, 1 resimden 1.
    • Cut a piece of scrap fabric slightly larger than the hole.
  3. How to Repair a Hole in a Duvet Insert: adım 3, 1 resimden 1.
    • Insert the fabric inside the hole, making sure the fabric covers the entirety of the opening.
  4. How to Repair a Hole in a Duvet Insert: adım 4, 1 resimden 1.
    • Carefully pin the patch in place, ensuring the entire opening is covered and secure.
  5. How to Repair a Hole in a Duvet Insert: adım 5, 1 resimden 1.
    • Insert thread in the needle hole and tie a slip knot at the end of the thread.
    • Keep extra thread pulled through the needle to prevent it from unthreading. If it does, re-thread and continue.
  6. How to Repair a Hole in a Duvet Insert: adım 6, 3 resimden 1. How to Repair a Hole in a Duvet Insert: adım 6, 3 resimden 2. How to Repair a Hole in a Duvet Insert: adım 6, 3 resimden 3.
    • Insert the needle in one of the corners of your patch, being sure to pierce through both the duvet insert and patch.
    • Continue stitching around the perimeter of the patch with stitches around 1/4 of an inch long until you have reached your previous starting point.
  7. How to Repair a Hole in a Duvet Insert: adım 7, 2 resimden 1. How to Repair a Hole in a Duvet Insert: adım 7, 2 resimden 2.
    • Sew around the hole's edges to secure the duvet insert into the patch to prevent future tearing.
  8. How to Repair a Hole in a Duvet Insert: adım 8, 3 resimden 1. How to Repair a Hole in a Duvet Insert: adım 8, 3 resimden 2. How to Repair a Hole in a Duvet Insert: adım 8, 3 resimden 3.
    • Once finished, tie 1-2 knots and cut the thread off.
    • Make sure to leave 1/4 inch between the cut and the knot to prevent the knot from coming undone.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Ben Arnold-Galati
187 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S3G3
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 254
