Giriş
Do you have a hole in your Therm-a-Rest backpacking sleeping pad? Follow this guide to locate and patch the hole in your pad using a Therm-a-Rest repair kit, and get back to camping in comfort.
Parçalar
Blow up the sleeping pad full of air using the intake valve in the top left corner.
Open the valve by turning it counter-clock-wise.
Place your mouth over the valve, and blow air into the pad until is is inflated.
With your mouth over the valve, turn the valve clockwise to close it.
This guide can be used to fix similar types of sleeping pads. This patch will help you prolong the life of your camping gear!
Bir başkası bu kılavuzu tamamladı.
3 Yorum
Do I need to deflate the mat before applying the glue?
You could try submerging the inflated sleeping pad in a bathtub. Keep an eye out for small bubbles and you should find your leak.
