Ana içeriğe geç
How to Repair a Hole in an Air Mattress
Neye ihtiyacın var
  1. How to Repair a Hole in an Air Mattress, How to Repair a Hole in an Air Mattress: adım 1, 1 resimden 1.
    • Inflate the air mattress fully using either a manual pump (pictured) or an electric pump.
    • An electric pump will save you time and energy so if you have that option definitely choose the electric pump, but know that means you need access to a plug.
  2. How to Repair a Hole in an Air Mattress: adım 2, 1 resimden 1.
    • Identify the location of the hole.
    • Some techniques to locate holes are listening for air escaping or using soapy water.
  3. How to Repair a Hole in an Air Mattress: adım 3, 1 resimden 1.
    • Clean around the hole where you plan to put the patch.
    • Use water and allow to air dry.
    • This will ensure a clean surface to attach the adhesive.
  4. How to Repair a Hole in an Air Mattress: adım 4, 2 resimden 1. How to Repair a Hole in an Air Mattress: adım 4, 2 resimden 2.
    • Apply flexible adhesive made for vinyl where the patch is intended.
    • Use a brush or towel to spread adhesive to form an even layer.
  5. How to Repair a Hole in an Air Mattress: adım 5, 2 resimden 1. How to Repair a Hole in an Air Mattress: adım 5, 2 resimden 2.
    • Apply a piece of vinyl patch on top of the adhesive to cover the hole.
    • Smooth out patches to ensure there are no bumps or bubbles.
    • You can smooth out bubbles with your fingers or use a plastic card.
  6. How to Repair a Hole in an Air Mattress: adım 6, 1 resimden 1.
    • Allow the adhesive to fully dry per adhesive instructions before using the air mattress.
    • Enjoy your fixed air mattress!
Sonuç
To fill any other holes, repeat the same steps as many times as necessary.
Senia
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 209
