Ana içeriğe geç
How to Repair a Hole in an Inflatable Floatie
Neye ihtiyacın var
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: adım 1, 3 resimden 1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: adım 1, 3 resimden 2. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: adım 1, 3 resimden 3.
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: adım 2, 2 resimden 1. How to Repair a Hole in an Inflatable Floatie: adım 2, 2 resimden 2.
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: adım 3, 3 resimden 1. How to Repair a Hole in an Inflatable Floatie: adım 3, 3 resimden 2. How to Repair a Hole in an Inflatable Floatie: adım 3, 3 resimden 3.
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: adım 4, 3 resimden 1. How to Repair a Hole in an Inflatable Floatie: adım 4, 3 resimden 2. How to Repair a Hole in an Inflatable Floatie: adım 4, 3 resimden 3.
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: adım 5, 3 resimden 1. How to Repair a Hole in an Inflatable Floatie: adım 5, 3 resimden 2. How to Repair a Hole in an Inflatable Floatie: adım 5, 3 resimden 3.
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: adım 6, 2 resimden 1. How to Repair a Hole in an Inflatable Floatie: adım 6, 2 resimden 2.
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
Sonuç
Enjoy your renewed floatie!
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 164
