Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Clean the outsole with a wet paper towel.
Clean and dry the outsole with a paper towel before starting.
Use the 120 grit sandpaper to roughen the edges of the hole on the outsole.
Pull the insole out of the shoe.
Apply duct tape inside the shoe (on the other side of the hole).
Make sure the duct tape covers up the entire hole, so there will be no shoe goo going through the sole into the shoe.
Apply the shoe goo to fill up the hole on the outsole.
Spread the shoe goo evenly with an ice cube to cover up any uncovered area.
Let the shoe sit for 24 hours for the shoe goo to dry.
After 24 hours, remove the duct tape from the shoe.
Place the insole back into the shoe.
Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth.
30 farklı kişi bu kılavuzu tamamladı.
10 Yorum
Excellent - thank you
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
