Ana içeriğe geç
How to Repair a Jammed 2007 GMC Envoy Tailgate
Neye ihtiyacın var
  1. How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: adım 1, 3 resimden 1. How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: adım 1, 3 resimden 2. How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: adım 1, 3 resimden 3.
    • Use the flat head screwdriver to pry off the small round access panel on the interior of the tailgate.
  2. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 2, 2 resimden 1. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 2, 2 resimden 2.
    • Look through the opening and stick your flat head screwdriver underneath this metal arm.
    • Force the arm up. It should stay raised when you pull the screwdriver out.
    • DO NOT USE YOUR FINGER, there is risk of pinching and injury if you do not use the specified tools.
  3. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 3, 3 resimden 1. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 3, 3 resimden 2. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 3, 3 resimden 3.
    • Use the flat head screwdriver to push this second lever to the right as far as it will go or until it clicks.
  4. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 4, 2 resimden 1. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 4, 2 resimden 2.
    • The tailgate is now unlatched. Open it from the outside.
    • Replace the access panel.
    • If the tailgate will still not open, you most likely did not push the second lever over far enough. Repeat Step 3.
  5. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 5, 2 resimden 1. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 5, 2 resimden 2.
    • Inspect the latch bracket's horizontal and vertical bars for dents, warping, and corrosion.
    • If there are no physical defects visible, clean any rust and corrosion and test the tailgate. If it still jams, repeat Steps 1-4 and move on to Step 6.
  6. How to Repair a Jammed 2007 GMC Envoy Tailgate: adım 6, 1 resimden 1.
    • Use the 40 Torx screwdriver to remove the two T40 63.5 mm screws that secure the latch bracket.
    • Remove the latch from the vehicle.
Sonuç
To reassemble your device, follow these steps in reverse order.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 85
Her zaman: 3,128
