Ana içeriğe geç
How to Repair a Knotted Chain
Neye ihtiyacın var
  1. How to Repair a Knotted Chain, How to Repair a Knotted Chain: adım 1, 1 resimden 1.
    • Find a flat surface.
    • Remove all clutter from your workspace to ensure you can access the chain easily.
    • The flat surface will provide stability when you begin working through the tangles and will prevent other tangles from forming during the process.
  2. How to Repair a Knotted Chain: adım 2, 3 resimden 1. How to Repair a Knotted Chain: adım 2, 3 resimden 2. How to Repair a Knotted Chain: adım 2, 3 resimden 3.
    • Rest the chain on the surface.
    • Slowly spread the chain out so you can recognize the tangled areas.
    • While spreading the chain on the surface, make sure to do so slowly in order to avoid tightening the tangle.
  3. How to Repair a Knotted Chain: adım 3, 3 resimden 1. How to Repair a Knotted Chain: adım 3, 3 resimden 2. How to Repair a Knotted Chain: adım 3, 3 resimden 3.
    • Unclasp the chain.
    • Separate the strands gently.
    • Opening the clasp will isolate the chain strands, permitting them to slide through the knots easily.
  4. How to Repair a Knotted Chain: adım 4, 2 resimden 1. How to Repair a Knotted Chain: adım 4, 2 resimden 2.
    • Gently sprinkle baby powder onto the knotted area.
    • Sprinkle the powder until the knot is lightly coated.
    • This is an optional step.
  5. How to Repair a Knotted Chain: adım 5, 3 resimden 1. How to Repair a Knotted Chain: adım 5, 3 resimden 2. How to Repair a Knotted Chain: adım 5, 3 resimden 3.
    • Bring your thumb and index finger into a pinching pose.
    • Put the knot between the thumb and index finger.
    • Carefully and gently lightly rub the knot together.
  6. How to Repair a Knotted Chain: adım 6, 2 resimden 1. How to Repair a Knotted Chain: adım 6, 2 resimden 2.
    • Insert two toothpicks between the focal point of the knot.
    • Any fine toothpick style tool can work to untangle the knot.
  7. How to Repair a Knotted Chain: adım 7, 3 resimden 1. How to Repair a Knotted Chain: adım 7, 3 resimden 2. How to Repair a Knotted Chain: adım 7, 3 resimden 3.
    • Gently draw the toothpicks from one another to open and release the tight knot.
    • When you get an opening in the knot using the toothpicks, take it apart by pulling each separated strand through the knot to fully open it.
    • Then slowly pull apart the loosened knot to separate the chain strands.
  8. How to Repair a Knotted Chain: adım 8, 2 resimden 1. How to Repair a Knotted Chain: adım 8, 2 resimden 2.
    • Restore chain back into its original form.
    • Clasp the chain to avoid it from re-tangling.
  9. How to Repair a Knotted Chain: adım 9, 2 resimden 1. How to Repair a Knotted Chain: adım 9, 2 resimden 2.
    • Wipe the chain with a damp towel or tissue before use.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 547
