Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Find a flat surface.
Remove all clutter from your workspace to ensure you can access the chain easily.
Rest the chain on the surface.
Slowly spread the chain out so you can recognize the tangled areas.
Gently sprinkle baby powder onto the knotted area.
Sprinkle the powder until the knot is lightly coated.
Bring your thumb and index finger into a pinching pose.
Put the knot between the thumb and index finger.
Carefully and gently lightly rub the knot together.
Insert two toothpicks between the focal point of the knot.
Gently draw the toothpicks from one another to open and release the tight knot.
When you get an opening in the knot using the toothpicks, take it apart by pulling each separated strand through the knot to fully open it.
Then slowly pull apart the loosened knot to separate the chain strands.
Restore chain back into its original form.
Clasp the chain to avoid it from re-tangling.
Wipe the chain with a damp towel or tissue before use.
2 farklı kişi bu kılavuzu tamamladı.
