Ana içeriğe geç
How to Repair a Locket Hinge
Neye ihtiyacın var
  1. How to Repair a Locket Hinge, How to Repair a Locket Hinge: adım 1, 3 resimden 1. How to Repair a Locket Hinge, How to Repair a Locket Hinge: adım 1, 3 resimden 2. How to Repair a Locket Hinge, How to Repair a Locket Hinge: adım 1, 3 resimden 3.
    • Use pliers to carefully bend the damaged hinge back into place.
    • You want the hinge to be rounded and hollow, like a straw.
    • Test the hinge with some wire. If you can easily thread the wire through, then you can move on to Step 2. If not, keep bending.
  2. How to Repair a Locket Hinge: adım 2, 3 resimden 1. How to Repair a Locket Hinge: adım 2, 3 resimden 2. How to Repair a Locket Hinge: adım 2, 3 resimden 3.
    • Hold both ends of the wire.
    • Place the middle of the wire against a hard edge. Hold the wire so that it is perpendicular to the edge.
    • Straighten the wire by pulling it against the edge.
  3. How to Repair a Locket Hinge: adım 3, 2 resimden 1. How to Repair a Locket Hinge: adım 3, 2 resimden 2.
    • Bend the wire to match the contours of your locket.
    • If your locket is rounded, your wire will have to be curved. If your locket is straight, your wire will have to be straight.
  4. How to Repair a Locket Hinge: adım 4, 2 resimden 1. How to Repair a Locket Hinge: adım 4, 2 resimden 2.
    • Cut the wire to a manageable length. We suggest the length of the hinges plus some excess.
  5. How to Repair a Locket Hinge: adım 5, 3 resimden 1. How to Repair a Locket Hinge: adım 5, 3 resimden 2. How to Repair a Locket Hinge: adım 5, 3 resimden 3.
    • Match and align the front and back of the locket.
    • The holes of the hinge must be aligned, making a tunnel for the wire.
    • Line up the curved wire to match the locket shape.
    • Feed the wire through the hole of the hinge.
  6. How to Repair a Locket Hinge: adım 6, 3 resimden 1. How to Repair a Locket Hinge: adım 6, 3 resimden 2. How to Repair a Locket Hinge: adım 6, 3 resimden 3.
    • Hold the locket closed.
    • Glue the top of the hinge.
    • Glue the bottom of the hinge.
    • Do not glue the center of the hinge.
  7. How to Repair a Locket Hinge: adım 7, 2 resimden 1. How to Repair a Locket Hinge: adım 7, 2 resimden 2.
    • Hold the locket closed and hammer the side with the hinge and wire.
    • Tap firmly along the hinge and wire to secure.
  8. How to Repair a Locket Hinge: adım 8, 2 resimden 1. How to Repair a Locket Hinge: adım 8, 2 resimden 2.
    • Cut the excess wire.
  9. How to Repair a Locket Hinge: adım 9, 2 resimden 1. How to Repair a Locket Hinge: adım 9, 2 resimden 2.
    • The final product, the locket hinge is fixed and the locket can be used.
Bitiş Çizgisi
Daisy J Williams
169 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-3, Andersen Winter 2024 UC Davis, Team 4-3, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S4G3
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 360
