Ana içeriğe geç
How to Repair a Loose Modern Gooseneck Water Faucet
Neye ihtiyacın var
  1. How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: adım 1, 3 resimden 1. How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: adım 1, 3 resimden 2. How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: adım 1, 3 resimden 3.
    • On the bottom of the sink, you will see a water tank.
    • The next step is to close the vault. Slowly turn the vault to the right side.
    • You can see the vault is 90 degrees opposite to the direction when it was opened. That means it is now closed.
  2. How to Repair a Loose Modern Gooseneck Water Faucet: adım 2, 3 resimden 1. How to Repair a Loose Modern Gooseneck Water Faucet: adım 2, 3 resimden 2. How to Repair a Loose Modern Gooseneck Water Faucet: adım 2, 3 resimden 3.
    • Check again by opening the tap to see if water is coming out of it or not.
    • Due to the loose neck, water is leaking from the sink.
    • The leakage can cause damage in the future, so, it is necessary to tighten the loose neck of the water dispenser.
  3. How to Repair a Loose Modern Gooseneck Water Faucet: adım 3, 3 resimden 1. How to Repair a Loose Modern Gooseneck Water Faucet: adım 3, 3 resimden 2. How to Repair a Loose Modern Gooseneck Water Faucet: adım 3, 3 resimden 3.
    • Readjust the pipe to the way it was originally.
    • Make sure the realignment is properly done and that there are no gaps in it.
    • After, check the realignment from all sides so there are no places from where it can leak.
  4. How to Repair a Loose Modern Gooseneck Water Faucet: adım 4, 3 resimden 1. How to Repair a Loose Modern Gooseneck Water Faucet: adım 4, 3 resimden 2. How to Repair a Loose Modern Gooseneck Water Faucet: adım 4, 3 resimden 3.
    • Use a wrench to adjust and tighten the screw on the right side to secure it in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 221
