Ana içeriğe geç
How to Repair a Loose Rear Bicycle Wheel
Neye ihtiyacın var
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: adım 1, 3 resimden 1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: adım 1, 3 resimden 2. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: adım 1, 3 resimden 3.
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: adım 2, 2 resimden 1. How to Repair a Loose Rear Bicycle Wheel: adım 2, 2 resimden 2.
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: adım 3, 2 resimden 1. How to Repair a Loose Rear Bicycle Wheel: adım 3, 2 resimden 2.
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: adım 4, 2 resimden 1. How to Repair a Loose Rear Bicycle Wheel: adım 4, 2 resimden 2.
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: adım 5, 2 resimden 1. How to Repair a Loose Rear Bicycle Wheel: adım 5, 2 resimden 2.
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: adım 6, 3 resimden 1. How to Repair a Loose Rear Bicycle Wheel: adım 6, 3 resimden 2. How to Repair a Loose Rear Bicycle Wheel: adım 6, 3 resimden 3.
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: adım 7, 3 resimden 1. How to Repair a Loose Rear Bicycle Wheel: adım 7, 3 resimden 2. How to Repair a Loose Rear Bicycle Wheel: adım 7, 3 resimden 3.
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
Sonuç
Lily Suggs
145 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-8, Andersen Winter 2023 UC Davis, Team 4-8, Andersen Winter 2023 üyesi
UCD-ANDERSEN-W23S4G8
3 Üyeler
1 Kılavuz yazıldı
1Rehber Yorum
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 46
Her zaman: 1,061
