Ana içeriğe geç
How to Repair a Loose Webbing Strap in a Backpack
Neye ihtiyacın var
  1. How to Repair a Loose Webbing Strap in a Backpack, Identify the repair area: adım 1, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Identify the repair area: adım 1, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Identify the repair area: adım 1, 3 resimden 3.
    • Identify the defective area and assess how large the damage is.
  2. How to Repair a Loose Webbing Strap in a Backpack, Prepare the straps: adım 2, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Prepare the straps: adım 2, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Prepare the straps: adım 2, 3 resimden 3.
    • Cut away the tips of the straps to create a clean surface to repair.
    • Note: In this example, we cut 2 cm away from the tip.
    • Pin the two straps together and set aside.
  3. How to Repair a Loose Webbing Strap in a Backpack, Clean the area: adım 3, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Clean the area: adım 3, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Clean the area: adım 3, 3 resimden 3.
    • Use a "seam ripper" tool to unstitch the remaining piece of strap.
    • Note: This will leave a hole in the border of the backpack (red circle), that will be useful in the next step.
  4. How to Repair a Loose Webbing Strap in a Backpack, Hold the straps: adım 4, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Hold the straps: adım 4, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Hold the straps: adım 4, 3 resimden 3.
    • Insert the pinned straps inside the hole and use a safety pin to hold the pieces together.
  5. How to Repair a Loose Webbing Strap in a Backpack, Turn the backpack inside-out: adım 5, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Turn the backpack inside-out: adım 5, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Turn the backpack inside-out: adım 5, 3 resimden 3.
    • Locate the straps that were inserted in the previous step (red circle).
  6. How to Repair a Loose Webbing Strap in a Backpack, Clean the area before stitching: adım 6, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Clean the area before stitching: adım 6, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Clean the area before stitching: adım 6, 3 resimden 3.
    • Cut away the remaining pieces of the binding material that were present before (yellow arrows).
  7. How to Repair a Loose Webbing Strap in a Backpack, Stitch the strap: adım 7, 2 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Stitch the strap: adım 7, 2 resimden 2.
    • Use a straight stitch to fix the strap in the right position.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
  8. How to Repair a Loose Webbing Strap in a Backpack, Reenforce the seam: adım 8, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Reenforce the seam: adım 8, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Reenforce the seam: adım 8, 3 resimden 3.
    • Change the settings in the sewing machine and switch from a "straight" to a "zigzag" stich.
    • Sew along the same line of the previous step.
  9. How to Repair a Loose Webbing Strap in a Backpack, Clean the area: adım 9, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Clean the area: adım 9, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Clean the area: adım 9, 3 resimden 3.
    • Locate the remaining piece of strap (red line) and cut it out.
  10. How to Repair a Loose Webbing Strap in a Backpack, Pin the "binding" strap: adım 10, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Pin the "binding" strap: adım 10, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Pin the "binding" strap: adım 10, 3 resimden 3.
    • Select a "binding" material, it can be a strap or any spare textile you have at home.
    • Make sure it is the same length as the area you are trying to repair (red line).
    • Fold the side of binding strap inwards (yellow arrow) and fix the position using with pins.
  11. How to Repair a Loose Webbing Strap in a Backpack, Sew the "binding" strap to the inner part: adım 11, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Sew the "binding" strap to the inner part: adım 11, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Sew the "binding" strap to the inner part: adım 11, 3 resimden 3.
    • Change the settings in the sewing machine and switch back to a "straight" stich.
    • Start sewing and remove any pins in the way of the sewing route.
    • Turn the backpack inside-out to return to the original position.
  12. How to Repair a Loose Webbing Strap in a Backpack, Finished and ready!: adım 12, 3 resimden 1. How to Repair a Loose Webbing Strap in a Backpack, Finished and ready!: adım 12, 3 resimden 2. How to Repair a Loose Webbing Strap in a Backpack, Finished and ready!: adım 12, 3 resimden 3.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Sonuç
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Bir başkası bu kılavuzu tamamladı.
Ben Blischke
10.230 İtibar
66 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 975
