Ana içeriğe geç
How to Repair a Painting Frame
Neye ihtiyacın var
  1. How to Repair a Painting Frame, How to Repair a Painting Frame: adım 1, 3 resimden 1. How to Repair a Painting Frame, How to Repair a Painting Frame: adım 1, 3 resimden 2. How to Repair a Painting Frame, How to Repair a Painting Frame: adım 1, 3 resimden 3.
    • Wipe the frame with a damp cloth.
  2. How to Repair a Painting Frame: adım 2, 1 resimden 1.
    • Use a paper plate to mix the epoxy adhesives with a wooden stick.
    • Follow the instructions on your specific package of epoxy adhesive.
    • Make sure to use the glue within 45 minutes after mixing.
  3. How to Repair a Painting Frame: adım 3, 1 resimden 1.
    • Flip the glass painting and remove the frame joints.
  4. How to Repair a Painting Frame: adım 4, 3 resimden 1. How to Repair a Painting Frame: adım 4, 3 resimden 2. How to Repair a Painting Frame: adım 4, 3 resimden 3.
    • Use a wooden stick to apply a thin layer of glue on the edges of the frame.
  5. How to Repair a Painting Frame: adım 5, 3 resimden 1. How to Repair a Painting Frame: adım 5, 3 resimden 2. How to Repair a Painting Frame: adım 5, 3 resimden 3.
    • Put the glass painting over the glue and close the frame's metal clamps.
  6. How to Repair a Painting Frame: adım 6, 1 resimden 1.
    • Seal the clamps with duct tape for protection.
    • Repeat Steps 5-7 on all sides of the painting. It is suggested to place painting over the surface so it will be easier to apply the glue.
    • Once all four sides are done, clamp the corners with safety tape.
    • Let the glue dry for a minimum of 24 hours.
  7. How to Repair a Painting Frame: adım 7, 2 resimden 1. How to Repair a Painting Frame: adım 7, 2 resimden 2.
    • Remove all the tape from the metal clamps and the corners of the frame.
  8. How to Repair a Painting Frame: adım 8, 1 resimden 1.
    • After that, you will have a restored painting frame.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 448
