Ana içeriğe geç
How to Repair a Patio Solar Light
Neye ihtiyacın var
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: adım 1, 1 resimden 1.
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: adım 2, 1 resimden 1.
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: adım 3, 1 resimden 1.
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: adım 4, 1 resimden 1.
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: adım 5, 3 resimden 1. How to Repair a Patio Solar Light: adım 5, 3 resimden 2. How to Repair a Patio Solar Light: adım 5, 3 resimden 3.
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: adım 6, 1 resimden 1.
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
Sonuç
Miguel Antonio Gonzales
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 221
