Ana içeriğe geç
How to Repair a Resin Charm
Neye ihtiyacın var
  1. How to Repair a Resin Charm, How to Repair a Resin Charm: adım 1, 2 resimden 1. How to Repair a Resin Charm, How to Repair a Resin Charm: adım 1, 2 resimden 2.
    • Fit the broken pieces together with the flattest side of the charm facing towards you.
  2. How to Repair a Resin Charm: adım 2, 2 resimden 1. How to Repair a Resin Charm: adım 2, 2 resimden 2.
    • Lay a piece of tape on the crack and press down smoothly.
  3. How to Repair a Resin Charm: adım 3, 1 resimden 1.
    • Pick up the pieces so the crack is facing up.
    • Bend the pieces to create a slight gap.
    • CAUTION: Wear gloves when working with resin.
  4. How to Repair a Resin Charm: adım 4, 2 resimden 1. How to Repair a Resin Charm: adım 4, 2 resimden 2.
    • Add resin to the crack.
    • Press the pieces together.
  5. How to Repair a Resin Charm: adım 5, 2 resimden 1. How to Repair a Resin Charm: adım 5, 2 resimden 2.
    • Use a cotton swab to spread the resin in the crack.
    • Pick up the excess resin with a cotton swab.
  6. How to Repair a Resin Charm: adım 6, 3 resimden 1. How to Repair a Resin Charm: adım 6, 3 resimden 2. How to Repair a Resin Charm: adım 6, 3 resimden 3.
    • Turn on the UV light.
    • Put the charm under the UV light for 120 seconds per side.
    • Remove the charm.
Sonuç
Now your charm is repaired and can once again be worn or displayed!
Jorja
133 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-7, Whithaus Spring 2024 UC Davis, Team 2-7, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S2G7
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 116
