Giriş
When a lunch bag handle gets ripped, people deem it unusable and end up buying a new one. In order to reduce waste, this guide is to instruct how to repair that rip using a few simple steps. No prior knowledge of how to sew is required as this guide will teach you step by step.
Neye ihtiyacın var
Find colored thread to match the color of the lunch bag and a needle.
Thread the needle through the lunchbox and handle. Pull all the way through, until the knot stops. Start on the inside, so the knot is not visible at the end. Stick the needle the opposite direction, about a ¼” away from the first stitch. Leave room between your first and second stitch.
To end the last stitch, thread the needle between the lunchbox and thread of your last stitch. Rather than pulling the thread completely through, thread the needle back through the excess thread to make a knot.
You can continue looping the needle about the thread to make the knot extra secure.
Now your lunch bag should be good as new. There's no reason to throw a perfectly good lunch bag away when there's such a simple fix. Happy lunching!
Bir başkası bu kılavuzu tamamladı.
