Ana içeriğe geç
How to Repair a Stuck Toilet Handle
Neye ihtiyacın var
  1. How to Repair a Stuck Toilet Handle, How to Repair a Stuck Toilet Handle: adım 1, 2 resimden 1. How to Repair a Stuck Toilet Handle, How to Repair a Stuck Toilet Handle: adım 1, 2 resimden 2.
    • Find the shut off valve behind the toilet.
    • To close the shut off valve, most toilet valves need to be turned to the left.
  2. How to Repair a Stuck Toilet Handle: adım 2, 2 resimden 1. How to Repair a Stuck Toilet Handle: adım 2, 2 resimden 2.
    • Remove the lid from the tank of your toilet.
    • Find the nut inside of the tank that holds your toilet’s lever.
  3. How to Repair a Stuck Toilet Handle: adım 3, 1 resimden 1.
    • Using your hand or an appropriately sized wrench, loosen the nut a little.
    • If your toilet handle is still sticking, move to the next step.
  4. How to Repair a Stuck Toilet Handle: adım 4, 1 resimden 1.
    • Push the handle down slowly and watch the lever arm to make sure it is not touching anything.
    • The lever arm of your toilet handle cannot touch anything or else it might cause the handle to stick.
  5. How to Repair a Stuck Toilet Handle: adım 5, 2 resimden 1. How to Repair a Stuck Toilet Handle: adım 5, 2 resimden 2.
    • If your toilet’s lever arm is touching something, bend the metal so that this does not happen.
  6. How to Repair a Stuck Toilet Handle: adım 6, 2 resimden 1. How to Repair a Stuck Toilet Handle: adım 6, 2 resimden 2.
    • If your toilet’s lever arm is catching on the chain which connects it to the flapper at the bottom of the tank, then this will need to be remedied.
    • The length of the toilet chain can be adjusted by moving the hook a few links down and reattaching it to the lever.
Sonuç
To reassemble your toilet, turn the water valve back on and put the lid back on.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 1,043
