Giriş
If your trailer jack is not operating correctly or stuck from corrosion or rust, this guide will show you how to disassemble the trailer jack and remove the rust that causes the trailer jack to become stuck or inoperable.
The trailer jack is consisted of two assemblies. The upper assembly that is used for support and protection of the screw assembly. The lower assembly contains the foot of the jack and the screw assembly of the jack. The screw is made of steel and over time will build up rust and cause the jack to not operate or become stuck.
Before using this guide, be sure to safely support the trailer that the jack is being removed from. This guide also includes the use of a die-grinder and eye and hand protection is suggested in the use of this equipment.
Neye ihtiyacın var
Remove the trailer jack from trailer.
Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
Slide the jack off the trailer to remove.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
