Ana içeriğe geç
Giriş
Have you ever had a backpack that tears when you need it most? Fear not, as this guide will teach you how to repair those tears so you do not have to buy a new one!
  1. First use scissors to cut off the destroyed nylon material inside of the backpack.
    • First use scissors to cut off the destroyed nylon material inside of the backpack.
  2. Using a ruler, cut out the appropriate length of nylon material to cover the tear inside of the backpack.
    • Using a ruler, cut out the appropriate length of nylon material to cover the tear inside of the backpack.
    • The nylon material needed for the tear size will be different for each backpack. Measure out how much material you need to cover the tear.
  3. Use push-pins to pin down each corner of the nylon material.
    • Use push-pins to pin down each corner of the nylon material.
  4. Put thread through the needle.  Double knot the thread to secure it on the needle.  Then cut the end of the thread and the double knot as well.
    • Put thread through the needle. Double knot the thread to secure it on the needle. Then cut the end of the thread and the double knot as well.
  5. A basic stitch will suffice. To do a basic stitch, just poke the needle through the nylon material until it is on the other side. Bring all of the thread through. Then push the needle back near the thread that was pulled through.
    • A basic stitch will suffice. To do a basic stitch, just poke the needle through the nylon material until it is on the other side. Bring all of the thread through. Then push the needle back near the thread that was pulled through.
    • Be careful not to poke yourself with the needle.
  6. Repeat until the nylon material is secure. This picture is an example of what a basic stitch should look like after repeating the stitch.
    • Repeat until the nylon material is secure. This picture is an example of what a basic stitch should look like after repeating the stitch.
  7. Once finished cut the remaining thread and double knot the thread. Trim off any excess nylon material that is not sewn down. If the nylon is secure, you have fully fixed the tear!
    • Once finished cut the remaining thread and double knot the thread. Trim off any excess nylon material that is not sewn down. If the nylon is secure, you have fully fixed the tear!
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Catherine Swing
221 İtibar
1 Kılavuz yazıldı
Takım
2 Yorum
My Lock Lock Luggage inside the “ inner cover got damage “ can repair ? where should deliver to ? how much for the cost?
衛德雄 - Yanıt
Have you seen this product? "'''fixmytear'''". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
https://www.amazon.com/Fixmytear-Magic-R...
https://www.amazon.com/fixmytear-Magic-R...
bobhunter50023 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 62
Her zaman: 8,343
