Ana içeriğe geç
How to Repair a Tear in a Camping Chair
Neye ihtiyacın var
  1. How to Repair a Tear in a Camping Chair, Identify the repair area: adım 1, 2 resimden 1. How to Repair a Tear in a Camping Chair, Identify the repair area: adım 1, 2 resimden 2.
    • Locate the tear that needs to be fixed.
  2. How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: adım 2, 3 resimden 1. How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: adım 2, 3 resimden 2. How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: adım 2, 3 resimden 3.
    • Use a screwdriver to disassemble the chair and then remove the parts piece by piece.
  3. How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: adım 3, 3 resimden 1. How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: adım 3, 3 resimden 2. How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: adım 3, 3 resimden 3.
    • Continue to take the pieces and set them aside until you reach the fabric that needs to be stitched.
    • In this step, you simply need to use your hands to slide off and gently remove each part.
  4. How to Repair a Tear in a Camping Chair, Organize the repair area: adım 4, 3 resimden 1. How to Repair a Tear in a Camping Chair, Organize the repair area: adım 4, 3 resimden 2. How to Repair a Tear in a Camping Chair, Organize the repair area: adım 4, 3 resimden 3.
    • Set aside all the components of the chair, sort them out in small groups and prepare for stitching.
  5. How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: adım 5, 3 resimden 1. How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: adım 5, 3 resimden 2. How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: adım 5, 3 resimden 3.
    • Use a pair of scissors to cut a piece of cloth.
    • Note: we recommend using a piece of cloth that matches the material of the torn fabric. In this example, we used a non-stretch fabric that had a similar texture and feel to the original.
    • Place the cloth underneath the tear and get ready for the next step.
  6. How to Repair a Tear in a Camping Chair, Prepare for stitching: adım 6, 3 resimden 1. How to Repair a Tear in a Camping Chair, Prepare for stitching: adım 6, 3 resimden 2. How to Repair a Tear in a Camping Chair, Prepare for stitching: adım 6, 3 resimden 3.
    • Use sewing pins to fix the piece of cloth in place. Put the pins around the tear, forming a "square" shape (green lines).
  7. How to Repair a Tear in a Camping Chair, Start sewing: adım 7, 3 resimden 1. How to Repair a Tear in a Camping Chair, Start sewing: adım 7, 3 resimden 2. How to Repair a Tear in a Camping Chair, Start sewing: adım 7, 3 resimden 3.
    • Use a straight stitch to sew a "square shape" around the tear.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Rotate the piece as much as you need to find the position that makes the stitching more comfortable.
    • Once you have completed the stitch, use a pair of scissors to clean the loose threads.
  8. How to Repair a Tear in a Camping Chair, Reinforce the stitch: adım 8, 3 resimden 1. How to Repair a Tear in a Camping Chair, Reinforce the stitch: adım 8, 3 resimden 2. How to Repair a Tear in a Camping Chair, Reinforce the stitch: adım 8, 3 resimden 3.
    • Adjust the sewing machine to the Zig-Zag stitch setting and the length to "3".
    • Stitch a diagonal line following the direction of the red arrow.
  9. How to Repair a Tear in a Camping Chair, Clean the area: adım 9, 3 resimden 1. How to Repair a Tear in a Camping Chair, Clean the area: adım 9, 3 resimden 2. How to Repair a Tear in a Camping Chair, Clean the area: adım 9, 3 resimden 3.
    • Use a pair of scissors to cut the loose parts around the stitch and clean the area.
  10. How to Repair a Tear in a Camping Chair, Reassemble the chair: adım 10, 3 resimden 1. How to Repair a Tear in a Camping Chair, Reassemble the chair: adım 10, 3 resimden 2. How to Repair a Tear in a Camping Chair, Reassemble the chair: adım 10, 3 resimden 3.
    • Start by putting the components back, first the repaired fabric and then the rest of the parts.
    • Screw back the pieces that were taken on the previous steps.
  11. How to Repair a Tear in a Camping Chair, Finished and ready!: adım 11, 3 resimden 1. How to Repair a Tear in a Camping Chair, Finished and ready!: adım 11, 3 resimden 2. How to Repair a Tear in a Camping Chair, Finished and ready!: adım 11, 3 resimden 3.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Sonuç
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10.230 İtibar
66 adet Kılavuz yazıldı
Ekip
INTERSPORT INTERSPORT üyesi
Community
25 Üyeler
169 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 39
Her zaman: 583
