Ana içeriğe geç
How to Repair a Vileda Turbo Mop Bucket Set
Neye ihtiyacın var
  1. How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: adım 1, 2 resimden 1. How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: adım 1, 2 resimden 2.
    • No Parts Required
  2. How to Repair a Vileda Turbo Mop Bucket Set: adım 2, 1 resimden 1.
    • Run the few drops of oil down the chrome shaft
Sonuç
Get back to work !
3 farklı kişi bu kılavuzu tamamladı.
Paul
822 İtibar
4 adet Kılavuz yazıldı
11Kılavuz Yorumları
I had the same problem but fixed it slightly different. I turned the empty bucket upside down, removed the four pz2 screws. Lifted out gearing in one piece. Removed rust/debris from two month old bucket stainless steel shaft and sprayed with water dispersant liquid. Reassembled. May sound complicated but very easy and thorough job. Only about 10 minutes, screwdriver and lubricant spray.
jimdeane77 - Yanıt
Hi Jim Thanks for your idea. Next time I will go a bit deeper into it. My bucket was already full and ready to go. The few drops of oil got it going straight away.
Paul - Yanıt
Sometimes there is too much rust into the gearing.
I replace it with “Octagonal One Way Needle Roller Bearing HF081412 8*14*12mm Fit for EasyMop” found on EBAY (10=$8.90 !)
Like a new ! I takes 10’ !
geek5537 - Yanıt
Thanks for the heads up , geek5537. Will take note of the part number. Stay safe.
Paul - Yanıt
Where I can buy new pedal? Mine is broken.
Emil Hakobian - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 95
Son 30 gün: 479
Her zaman: 27,665
