Ana içeriğe geç
How to Repair a Warped Sterling Silver Ring
Neye ihtiyacın var
  1. How to Repair a Warped Sterling Silver Ring, How to Repair a Warped Sterling Silver Ring: adım 1, 1 resimden 1.
    • Fill a cooking pot halfway full with water.
  2. How to Repair a Warped Sterling Silver Ring: adım 2, 2 resimden 1. How to Repair a Warped Sterling Silver Ring: adım 2, 2 resimden 2.
    • Place the pot with water on the stove.
    • Turn the stove burner on to medium heat.
    • Using a stove can cause burns. Be sure to watch where you place your hands or if there are people around who may accidentally be burned.
    • Gas stoves can expose excess gas into your house when they are not lit properly and can lead to unconsciousness or serious injuries.
  3. How to Repair a Warped Sterling Silver Ring: adım 3, 2 resimden 1. How to Repair a Warped Sterling Silver Ring: adım 3, 2 resimden 2.
    • Boil the water until it starts steaming.
    • Use tongs to hold the ring and place it in the steaming water.
    • Boiling water can cause burn injuries when splashed onto skin.
  4. How to Repair a Warped Sterling Silver Ring: adım 4, 1 resimden 1.
    • Release the grip on the ring, and let the ring sit at the bottom of the pot.
    • Remove the tongs from the pot and set them aside.
    • Boil the ring in the water for 5 minutes.
  5. How to Repair a Warped Sterling Silver Ring: adım 5, 2 resimden 1. How to Repair a Warped Sterling Silver Ring: adım 5, 2 resimden 2.
    • After 5 minutes, remove the ring from the boiling water using tongs.
    • Place the ring on a paper towel for 5 minutes to cool the metal.
    • The metal of the ring will be hot and can burn your skin.
  6. How to Repair a Warped Sterling Silver Ring: adım 6, 3 resimden 1. How to Repair a Warped Sterling Silver Ring: adım 6, 3 resimden 2. How to Repair a Warped Sterling Silver Ring: adım 6, 3 resimden 3.
    • Place the warped ring on a metal mandrel.
    • Pull the ring down the mandrel to the desired ring size.
    • Our desired ring size was a size 8.
  7. How to Repair a Warped Sterling Silver Ring: adım 7, 3 resimden 1. How to Repair a Warped Sterling Silver Ring: adım 7, 3 resimden 2. How to Repair a Warped Sterling Silver Ring: adım 7, 3 resimden 3.
    • Use a rubber mallet to gently pound the ring band until it is round again.
    • Be careful with your fingers while using the mallet.
    • Rotate the ring to check that it is round and smooth.
    • Pull the ring off the mandrel.
  8. How to Repair a Warped Sterling Silver Ring: adım 8, 1 resimden 1.
    • Place the restored ring on your desired finger.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 425
