Giriş
Have you ever broken that favorite picture frame you just couldn't simply throw away and get rid of? My guide will accomplish the fix of a picture frame, and repairing the broken piece to make it brand new. Completing this fix, a few helpful tips to look out for is making sure you have the correct tools, this fix is an important part in making sure you get to show off that favorite photo! Be aware of any sharp items and hazardous chemicals to the skin as well.
Neye ihtiyacın var
Pull back the metal clips that hold the frame, you may use the pliers to pull them back if needed.
Remove the back of the frame and find a safe spot for it. You will need it at the end of the guide to put it back together.
If the glass seem's to be cracked, handle the frame gently and wear gloves to prevent injury
After letting sit overnight, your glue should be dry and your frame should be as good as new!
Be sure to replace any glass that may had been broken when the frame collapsed.
Measure any dimensions with a tape measure to get an exact measurement of the glass, then cut with a glass cuter.
Insert new glass onto frame, and push down side clamps.
Bir başkası bu kılavuzu tamamladı.
