Ana içeriğe geç
How to Repair and Refinish Wooden Legs on Mirror
Neye ihtiyacın var
    1. How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: adım 1, 3 resimden 1. How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: adım 1, 3 resimden 2. How to Repair and Refinish Wooden Legs on Mirror, How to Repair and Refinish Wooden Legs on Mirror: adım 1, 3 resimden 3.
      • Inspect the damage from the chew marks.
      • If you have a mirror that is attached to the wood, be sure to cover the mirror to prevent damage. You can use painter's tape and cardboard to secure the mirror from damage.
      • Look for finer areas with smaller chewed up marks.
      FixBot'a Sor
      Yorum Ekle
    2. How to Repair and Refinish Wooden Legs on Mirror: adım 2, 2 resimden 1. How to Repair and Refinish Wooden Legs on Mirror: adım 2, 2 resimden 2.
      • Sand and clean the wooden legs in need of repair.
      • Be sure to wipe away all excess dirt and debris before applying stain.
      FixBot'a Sor
      Yorum Ekle
    3. How to Repair and Refinish Wooden Legs on Mirror: adım 3, 3 resimden 1. How to Repair and Refinish Wooden Legs on Mirror: adım 3, 3 resimden 2. How to Repair and Refinish Wooden Legs on Mirror: adım 3, 3 resimden 3.
      • Apply the wood filler using a putty knife or your fingers.
      • If you use your fingers, be sure to press the wood filler into the chewed marks
      • Then smooth over with your finger.
      • Wood filler does dry quickly, so work fast if you are not using gloves.
      FixBot'a Sor
      Yorum Ekle
    4. How to Repair and Refinish Wooden Legs on Mirror: adım 4, 1 resimden 1.
      • Allow the wood filler to dry (anywhere from 15 minutes to 8 hours).
      • Be sure to read the instructions on the wood filler for the allotted amount of time.
      FixBot'a Sor
      Yorum Ekle
    5. How to Repair and Refinish Wooden Legs on Mirror: adım 5, 2 resimden 1. How to Repair and Refinish Wooden Legs on Mirror: adım 5, 2 resimden 2.
      • Sand the filled area that its height is level the surrounding wood.
      • Sand the wood filler until it becomes smooth.
      • Be sure to sand the wood filler to match the same height and angle of the shape of the legs or furniture.
      FixBot'a Sor
      Yorum Ekle
    6. How to Repair and Refinish Wooden Legs on Mirror: adım 6, 1 resimden 1.
      • Match the stain to the wood using a scrap piece of wood.
      • Minwax is the best brand to use with a variety of stains.
      • If you are not using gloves, be careful when staining because it can take multiple washes to get the stain off your hands and clothing.
      • Use gloves when staining.
      FixBot'a Sor
      Yorum Ekle
    7. How to Repair and Refinish Wooden Legs on Mirror: adım 7, 2 resimden 1. How to Repair and Refinish Wooden Legs on Mirror: adım 7, 2 resimden 2.
      • Apply the stain to the wood using a small paintbrush.
      • Be sure to use a staining brush, you can find them in the aisle next to the stains.
      FixBot'a Sor
      Yorum Ekle
    8. How to Repair and Refinish Wooden Legs on Mirror: adım 8, 3 resimden 1. How to Repair and Refinish Wooden Legs on Mirror: adım 8, 3 resimden 2. How to Repair and Refinish Wooden Legs on Mirror: adım 8, 3 resimden 3.
      • Allow the stain to dry (depends on the stain; oil: 12 hours avg or water-based: 3-4 hours).
      • It may appear shiny and wet, so keep the wood out of the way.
      FixBot'a Sor
      Yorum Ekle
    9. How to Repair and Refinish Wooden Legs on Mirror: adım 9, 1 resimden 1.
      • Repeat steps 7-8 for the desired stain.
      • On this particular guide, the staining process took three coats.
      FixBot'a Sor
      Yorum Ekle
    10. How to Repair and Refinish Wooden Legs on Mirror: adım 10, 1 resimden 1.
      • Apply polyurethane sealer and let dry completely for 24 hours before reassembly.
      • Be sure the read the back of the polyurethane sealer for the allotted time.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Don’t forget to reassemble your wooden furniture. In this guide, the mirror has two screws that secure the mirror to its stand.
2 farklı kişi bu kılavuzu tamamladı.
Paula Lewis
261 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 15
Son 30 gün: 73
Her zaman: 1,655
