Ana içeriğe geç
How to Repair the Broken End of a Garden Hose
Neye ihtiyacın var
  1. How to Repair the Broken End of a Garden Hose, How to Repair the Broken End of a Garden Hose: adım 1, 1 resimden 1.
    • Measure the diameter of the inside of the original hose.
  2. How to Repair the Broken End of a Garden Hose: adım 2, 1 resimden 1.
    • Choose the right size of the hose end.
    • Know the difference between the male and female ends (the featured end is female).
    • Hoses typically come in sizes 5/8", 3/4", and 1/2".
  3. How to Repair the Broken End of a Garden Hose: adım 3, 1 resimden 1.
    • Remove the original broken end by using a utility knife to cut 2-3 inches from the hose.
    • Place the hose on a flat surface such as a workbench, and perform a smooth, straight cut.
  4. How to Repair the Broken End of a Garden Hose: adım 4, 1 resimden 1.
    • Remove the fitting.
  5. How to Repair the Broken End of a Garden Hose: adım 5, 3 resimden 1. How to Repair the Broken End of a Garden Hose: adım 5, 3 resimden 2. How to Repair the Broken End of a Garden Hose: adım 5, 3 resimden 3.
    • Attach the new fitting.
    • Slide the clamp onto the hose.
    • Insert the new fitting.
    • Soak the hose in warm water or let it sit in the sun to make it more pliable.
  6. How to Repair the Broken End of a Garden Hose: adım 6, 1 resimden 1.
    • Tighten the clamp with a screwdriver.
Sonuç
Test your new and improved hose by turning on the water and watching for leaks.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Warm water is a good idea.
pwkoughan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 40
Son 30 gün: 117
Her zaman: 6,039
