Ana içeriğe geç
How to Repair the Broken Toe Strap of a Fabric Sandal
Neye ihtiyacın var
  1. How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: adım 1, 2 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal, How to Repair the Broken Toe Strap of a Fabric Sandal: adım 1, 2 resimden 2.
    • Draw a rectangle on the bottom of the sandal that centers the hole of the toe strap.
  2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 2, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 2, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 2, 3 resimden 3.
    • Slice through three connecting sides at the bottom of the rectangle using a box cutter.
    • Keep your fingers away from the box cutter to avoid injury.
    • Create shallow slices to avoid cutting through the sandal.
  3. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 3, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 3, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 3, 3 resimden 3.
    • Insert a toothpick into the bottom slit.
    • Use the toothpick as a lever to wedge open the flap.
    • Use an extra toothpick if the first one breaks.
  4. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 4, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 4, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 4, 3 resimden 3.
    • Slide the toe strap through the hole of the sandal until you feel resistance.
  5. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 5, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 5, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 5, 3 resimden 3.
    • Flatten the toe strap against the insole of the sandal.
  6. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 6, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 6, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 6, 3 resimden 3.
    • Apply the glue to the toe strap and inside the flap of the sandal.
    • Wear protective gloves to avoid skin irritation.
  7. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 7, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 7, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 7, 3 resimden 3.
    • Close the sole flap.
    • Press the flap down until it is even with the sole of the sandal.
  8. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 8, 2 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 8, 2 resimden 2.
    • Use the trigger clamp to tightly press the flap against the sandal.
  9. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 9, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 9, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 9, 3 resimden 3.
    • Tighten the trigger clamp by squeezing the trigger.
    • Leave the trigger clamp on the sandal to dry overnight.
  10. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 10, 1 resimden 1.
    • Remove the trigger clamp by pressing the quick-release button.
  11. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 11, 3 resimden 1. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 11, 3 resimden 2. How to Repair the Broken Toe Strap of a Fabric Sandal: adım 11, 3 resimden 3.
    • Pour rubbing alcohol onto a paper towel.
    • Rub the paper towel over the shoe to remove pencil marks and excess glue.
Sonuç
If you properly follow the instructions in this guide, your sandal will be repaired to a lasting, wearable condition.
Kulthum Lakha
193 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 61
Her zaman: 2,577
