Ana içeriğe geç
How to Repair the Buttons on a Logitech Pebble Mouse
Neye ihtiyacın var
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: adım 1, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: adım 1, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: adım 1, 3 resimden 3.
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 2, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 2, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 2, 3 resimden 3.
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: adım 3, 2 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 3, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: adım 4, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 4, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 4, 3 resimden 3.
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: adım 5, 1 resimden 1.
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: adım 6, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 6, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 6, 3 resimden 3.
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Emma Whitmer
205 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-6, Morris Spring 2023 UC Davis, Team 2-6, Morris Spring 2023 üyesi
UCD-MORRIS-S23S2G6
3 Üyeler
1 Kılavuz yazıldı
5Kılavuz Yorumları
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - Yanıt
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - Yanıt
Hi Emma, Is it fine to use the spray version of wd40 if not what is the difference?
Best
Hakan
Hakan Toptas - Yanıt
I'm finding the issue with my new Pebble isn't so much that the buttons don't work. It's that they are unreliable because if you don't press near dead center on the button, it doesn't actuate enough to press the microswitch. I feel like this is a design flaw, but maybe this guide will help. On the plus side, at least they built it where it's easy to take apart.
Stephen Speck - Yanıt
Wow, it worked really well! Although on the first day, there were still some clicking issues. But by the second day, everything seemed fine
Yuriy Z - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 31
Son 30 gün: 173
Her zaman: 4,871
