Ana içeriğe geç
How to Replace 2007 Toyota Corolla Air Filter
Neye ihtiyacın var
  1. How to Replace 2007 Toyota Corolla Air Filter, Air Filter: adım 1, 3 resimden 1. How to Replace 2007 Toyota Corolla Air Filter, Air Filter: adım 1, 3 resimden 2. How to Replace 2007 Toyota Corolla Air Filter, Air Filter: adım 1, 3 resimden 3.
    • Pop your hood using the hood latch.
    • Release the latch under the front of the hood.
    • Open and prop the hood.
  2. How to Replace 2007 Toyota Corolla Air Filter: adım 2, 3 resimden 1. How to Replace 2007 Toyota Corolla Air Filter: adım 2, 3 resimden 2. How to Replace 2007 Toyota Corolla Air Filter: adım 2, 3 resimden 3.
    • Unclip the retaining clips from the air filter housing.
  3. How to Replace 2007 Toyota Corolla Air Filter: adım 3, 2 resimden 1. How to Replace 2007 Toyota Corolla Air Filter: adım 3, 2 resimden 2.
    • Disconnect the Mass Air Filter (MAF) sensor by releasing the latch on top of the sensor.
    • Pull away the clip and wires.
  4. How to Replace 2007 Toyota Corolla Air Filter: adım 4, 1 resimden 1.
    • Use a Phillips #3 screw driver to loosen the single screw securing the clamp to the intake pipe.
    • Do not remove the screw; simply loosen it until the clamp is loose enough to remove the intake pipe.
  5. How to Replace 2007 Toyota Corolla Air Filter: adım 5, 1 resimden 1.
    • Remove the air filter housing.
  6. How to Replace 2007 Toyota Corolla Air Filter: adım 6, 1 resimden 1.
    • Remove the old air filter.
Sonuç
Lauren Carter
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 92
Her zaman: 1,769
