Ana içeriğe geç
How to Replace Big Berkey Water Filters
Neye ihtiyacın var
  1. How to Replace Big Berkey Water Filters, Filters: adım 1, 2 resimden 1. How to Replace Big Berkey Water Filters, Filters: adım 1, 2 resimden 2.
    • Take the top half of your Berkey off, and place it to the side of your work station.
  2. How to Replace Big Berkey Water Filters: adım 2, 2 resimden 1. How to Replace Big Berkey Water Filters: adım 2, 2 resimden 2.
    • Unscrew the White Elements by twisting counterclockwise.
  3. How to Replace Big Berkey Water Filters: adım 3, 3 resimden 1. How to Replace Big Berkey Water Filters: adım 3, 3 resimden 2. How to Replace Big Berkey Water Filters: adım 3, 3 resimden 3.
    • Unscrew the Black Element filters by twisting the black washers counterclockwise.
    • Remove the filters from the top compartment.
  4. How to Replace Big Berkey Water Filters: adım 4, 2 resimden 1. How to Replace Big Berkey Water Filters: adım 4, 2 resimden 2.
    • Clean both the top and bottom tank compartments with a sponge.
    • Make sure to scrub both compartments clean of any mineral build-up that may have accumulated.
  5. How to Replace Big Berkey Water Filters: adım 5, 3 resimden 1. How to Replace Big Berkey Water Filters: adım 5, 3 resimden 2. How to Replace Big Berkey Water Filters: adım 5, 3 resimden 3.
    • Securely attach the priming tool to the Black Elements nozzle.
    • Push the filter nozzle against the tap for 10 seconds per filter to remove any impurities.
    • Run your sink water at a medium to slow flow-rate, to avoid water spraying everywhere.
  6. How to Replace Big Berkey Water Filters: adım 6, 2 resimden 1. How to Replace Big Berkey Water Filters: adım 6, 2 resimden 2.
    • Leave equipment to air dry.
  7. How to Replace Big Berkey Water Filters: adım 7, 3 resimden 1. How to Replace Big Berkey Water Filters: adım 7, 3 resimden 2. How to Replace Big Berkey Water Filters: adım 7, 3 resimden 3.
    • Place your new Black Element filters through the holes in the top compartment.
    • Continue to screw the washer around the nozzle to secure the Black Element in place.
  8. How to Replace Big Berkey Water Filters: adım 8, 3 resimden 1. How to Replace Big Berkey Water Filters: adım 8, 3 resimden 2. How to Replace Big Berkey Water Filters: adım 8, 3 resimden 3.
    • Screw our new White Element filters over the nozzle of the Black Element filters, and repeat to attach all pieces securely.
  9. How to Replace Big Berkey Water Filters: adım 9, 1 resimden 1.
    • Enjoy your clean and purified drinking water from your Big Berkey for years to come.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 502
